Anafi wont fly
You can break the Anafi into several subsystems and Ebay the parts I have done this 3 times on Anafi #5 now. The motor arms are worth 50-60 each camera with gimbal 100 battery 50 controller 50 and main body with boards 120. So this one could net you 400 plus that what I have got. Assuming only issue is one motor
The MavicMini is great I am on number 2. Only negative is the power to weight. First one got caught in updraft and was carried over 1.5 miles still transmitting datalink video 1280x768 never found. I replaced core drone only 250 usd. If you watch the wind speed this is my choice for low cost GPS drone.
You would not happen to know the weight of the gimbal/camera assembly? There aren't any ANAFI parts on eBay listed today that I could find.
I do not . There is a rebuild kit available
Parrot Anafi Mechanical kit (Body Pack, Arms, Frames, Antennas)
IN STOCK
As low as $10/mo or 0% APR with Affirm. Prequalify now
$99.00
For Parrot Anafi Work
If you need camera may be difficult
Reactions: randorf
I just got the 3 images from the seller
one of the screenshots shows that there is no SD card. You also need to be careful with this message, because after a fall, the SD card sometimes ceases to be read. There are many such situations on the forum
Jo Van de Vyver
