Hey everyone, recently had a meltdown, literally, with my Anbee Battery Charger.
Use caution with them. Video explains it all.
Great informational video. Your battery that you are wondering about I would have no problem using it. The case is just damaged, the actual battery is fine. I have a battery that was damaged with a fly away and will not snap in anymore so I use elastic bands to hold it in place. 20 flights later and it still works fine.
Nidge, I have not. I'm not that techie, but if you'd like, I'd be glad to ship it to you and see if you can determine the cause? Maybe if the cause was determined, it would benefit us all and we could pass the information on to Anbee? Just let me know and I'll get it shipped. Offer is open to anyone that has the skills/knowledge to perform on autopsy on it.Hi justDee.
Very scary indeed, but good to hear that Anbee stepped up and accepted responsibility.
I also have one of these chargers and thankfully it hasn’t given any cause for concern. However I’m now tempted to open it up to see what protection, if any, has been provided and if I need to add anything extra.
Out of curiosity have you had an opportunity to investigate what component(s) failed and caused that amount of heat?
Regards
Nidge.
I guess anything is possible, but the batteries, including the melted one, were cool to the touch when I pulled them from the melting charger. Now granted, the melting portion of the battery was not cool to the touch, but the rest of the battery was cool, no heat transfer to the majority of the body.
And you'd think, that if it was the battery, then the charging port on the battery, where it docks to the charger, would be melted? It is not and still connects to the drone without issues.
It can be quite ugly when batterries/chargers fail unless precautions are taken.It may have made a noise? We were in and out of that room throughout the day. Family was coming in from out of town, so we were busy cleaning the house and even had the vacuum cleaner going at some point before the source of the smell was located, so it could have made some noise and we just didn't hear it.
Hopefully, I'm the only one with the faulty circuit board?
Someone gave me the advice to set the charger/batteries inside a LIPO bag while charging and place the bag on a ceramic tile away from flammables. I have already ordered and received the LIPO bag, so I will be more cautious in the future.
Thanks for the review of the burnt parts.
Hi Dee
I think it would be better to have someone on your side of the pond to take up your offer as it would probably cost more than the original purchase price to ship it over here to the UK.
In the meantime I have opened up my charger unit and enclosed some pics. A little puzzling as there are no components in the area where the plastic case had melted, only a 25Volt/680uf electrolytic capacitor and 45Volt Schottky Diode either side of the damaged area.
Now Anbee’s suggestion of some loose solder causing a short is quite plausible as I found a few tiny solder splashes on the underside of the circuit board and some tiny solder balls on the edge of the Schottky Diode (see second picture), so I’m quite relieved I opened my unit and cleared these away. I would put this down to very poor finishing and quality control by the factory that Anbee sourced these chargers from.
Another possibility is the failure of the voltage regulator (TL431) on that charging port which could result in the battery itself overheating and being the cause of the damage, which is what I think is most likely due to the amount of damage to the battery casing.
Regards
Nidge.
View attachment 2155View attachment 2156
Sorry to hear of the loss if your charger and a battery. Thankfully there was no fire.
I always monitor a battery when it is charging, (charger and battery both go into my old toaster oven)and store them in a fireproof container. I am not willing to let my house burn down due to a "woulda-coulda-shoulda"
