Autolanding with low battery
Hello
Today it start autolanding with 40% battery left, no sense...look at the graph, battery has no strange discharge...I used many time this battery with no problem also at 5%
Any idea? It is a fw or sw bug?
The battery discharge curve on that screenshot does not look correct to me. The ones I have seen are usually nearly a straight line unless the flight modes are changed during flight. Was the battery fully charged before this flight? Do you gave some other flight records to compare the graph with.
Look at the altitude gain, it is obvious that if you push both the height and speed stick at max in race mode it discharge fast
Reactions: Bruchpilot
wow, did u fly at a height of 700m? Although not a valid cause of this behavior you do challenge the battery to the max. Race mode, 5% battery, extreme heights....
My guess is, that leaving the bird still on, the 10 minutes after landing, is doing this to the battery curve!
If he would have switched the bird off after 12 minutes in this record, the battery line would go from upper left to lower right. Which would be more like "a line", then, between start and stop
Edit: I strectched it a bit:
looks more "normal", methinks
PeeTeess
