Check out this video, is not my but looks scary. is it possible to set manually minimum battery level when drone should auto landing or set minimum level battery when RTH will turn on?
thank for replay, I understood now how it works, so referring to what you said anafi does not have the mode of automatic return home in the set battery percentage range?Sorry but i dont understand.
The video starts with the battery at 31%.
At some point it seems that the software is in version 1.5.6 !! (0.28)
I have normally landed only once with a 9% battery but this is my fault.
The manual as well as the experience of all users is clear.
Landing procedures should be performed to avoid problems after 20% of the battery life.
Τhe application turns yellow and warns you.
When it is red then an immediate landing must be made.
[...] As many, many users have found out to their unhappiness this feature does not work all that well, leading experienced users to recommend manual RTH at no less than 20%.
Interesting. Would you recommend that we who usually use 20% should run down to 5 or less % every TEN flights?..... Now, if you are one of those who tends to bring it in before the battery warning
of 10%, you may want to do this more often...
And Parrot is out of everything: "Recharge the battery after each use – within 20 minutes "
Who can do that, every time?
I am, mostly, on my second battery, 20 minutes after the first one.
And have other things in mind, as to start recharging with a power bank ;-)
But I have to admit, I could do that.
And switch, after flying the 3 battery, the PD-Powerbank to the second battery.
And another 20 minutes later, to the 3 battery.
Again: Who is doing that, please?
... Not sure who is ‘out of everything’... Parrot, or the one that misinterpreted the instructions ;o)
Wait at least 20 minutes for the battery to cool down before recharging !
And using the website,
Parrot Support Center | Parrot ANAFI drone FAQ
Need help? Troubleshooting, support FAQ and user guides for your ANAFI series drone: ANAFI, ANAFI Extended, ANAFI FPV, ANAFI Workwww.parrot.com
there stands at the bottom:
How to increase the lifetime of a battery
To preserve your battery as much as possible, be sure to follow the advice below:
- Never store a battery that is fully discharged.
- Charge your battery fully when using it for the first time.
- Do not charge a battery that is still warm.
- Recharge the battery after each use – within 20 minutes.
- Always carry your battery in a bag with fire protection.
- Always respect the charging time indicated in the instructions.
- Never use a swollen or damaged battery.
There are more sides to this, aren't there?
Now that my two batteries are almost 1 1/2 -2yrs old i always try to land before 20%.
