Camera error
simioh
I've flown my Anfi twice, and crashed it onto a light pole when backing up from about 6 feet/2 meters off the ground. It landed on the grass upside down, when I tried to conect again for liftoff there is a red message on the bottom of the screen saying "camera error, check that nothing is blocking the camera and restart the drone.
I've checked the camera and it moves freely, nothing looks broken but the message does not go away.
I tried to calibrate the camera through the settings but it doesn't do any anything.
Has anyone had this happen? Is there a solution?
Does the camera do it's calibration check at startup?
Have you checked that the cable from the camera to the body is attached and not damaged?
Me too!! With freeflight6 6.6.0. The drone is ok, it flies well. I have the message in yellow below. I did the calibration but it's like the didn't. Someone solved it?
