fly from outdoors to indoors
Bogwan035
Is it possible to fly a PB2 from outside of a structure inside of that structure through a window? I want to use the PB2 for SWAT calls but wonder how well it will do going through a window into a home. I did try this at an active SWAT call out but struck something and ended up inside the home. I was able to retrieve it with no damage other than one prop. I have seen a lot of videos where agencies have flown a DJI Mavic inside of a structure but really like my PB2 so thought I would ask. Thanks
I have not tried this but obviously as soon as you fly inside you will loose gps lock. I would suggest finding an open area indoors where you can try flying without gps and see how that goes. Even with gps, flying down a hallway of a house would take some skill. It would also be a good idea to have blade guards so that if you do bump into a wall the drone has a good chance of not going down.
fx1mark,
I have flown inside before and you're correct it is very difficult to control. I do have prop guards on the PB2 and am installing a LED light on the bottom to help with the underside camera.
Lombrounet
