- Joined
- Aug 28, 2018
- Messages
- 108
- Reaction score
- 89
I have a relatively inexpensive solution for viewing FPV with the Parrot Anafi. I use Vuzix iwear Goggles ($99) and ScreenBeam Mini 2 wireless display adapter ($49). Also required is an HDMI adapter female to female ($3.50) to connect the ScreenBeam to the goggles and a small power bank ($8) to supply voltage to the ScreenBeam.
I use my phone's (Samsung Note 5) Smart View feature to cast to the ScreenBeam which is connected by HDMI adapter to the Vuzix goggles. The latency is fairly low, not good enough for fast flying but fine for aerial photography.
The goggles mount on your head in a way so that you can look at the screen or look down and see underneath them to view the RC or phone. Without removing the goggles, you can tilt your head back and see the Anafi. The image is bright and easy to see in daylight. The resolution is 1280 x 720 each eye. The goggles fit over my glasses and I can see a clear, sharp image without need for adjustment or any added diotper lenses. These are the first goggles I have found that work well for me and I have tried a lot of them.
