no weights in controller
Hello ParrotAnafiFan,
Recently, Another Anafi user mentioned his SC3 didn’t have the heavy weights. My two controllers had them, quite possible later controllers are minus weights.
Enjoy the benefit of the lighter weighted controller, shouldn’t effect the controller in a negative way.
Enjoy the Anafi,
Paul
I found that when I removed the weights from my controller it then tipped back when put down on a flat surface with the phone attached. This put additional strain on the USB lead connected to my phone as it touched the ground so be aware of this.
well in that case do you have the weight of one of these blocks, i may want to add sinkers wrapped in hot glue or heatshrink. Or I can just always set it down on a soft surface, foam etc( can't think of any reason to set it down)
stefante
