Photos in flightplan don't work
Syncm
Wanted to make a ortophoto/3D map planed everything in flightplan. Started mission everything worked perfectly. Alltitude, direction orientation of camera. But home when I plugged in my laptop no pictures? It start to film when take off and land like planed. But the pictures with 6.7s intervals nothing? Any idea what went wrong?
Flightplan is a little buggy indeed. I tried the same. Was you taking a photo at each waypoint or just one photo command with 6 second interval?
The lowest setting to take a photo is 6 seconds, using 6 seconds you need to adjust your speed down to I think I used 5 meters per second. You need to load photos into each waypoint. I found the first way point did not want to take photos so I had to do that one by hand. After that it took photos every 6 seconds. You can tell it is taking photos by looking at your screen, it will flash like a camera.
Yeah you need an additions waypoint at the start to get the process going. I tend to add a pause at this dummy waypoint too
In fact, scrap that idea. I can't get it to take photos either now.
DjcheckThisDroneOut
