Related or independent issues with ANAFI USA and RC
chistiandolz1212
Hi all,
We have an ANAFI USA SE and a sky controller 3, and suddenly and seeming at the same time both started having issues (Listed below), if you have any suggestions or experiance would really appreciate the assistance. So far we have tried hard restting both the drone and the RC but no luck.
Drone issues:
1. Wont produce a WIFI signal
2. Wont bind with the RC (RC light blue light only)
RC issues:
1. Wont connect to the phone via FF6 App (however the phone makes a beep sound apparently detecting the RC but its not visible on the app)
Thank you so much all and Happy New Years!
Ref “Drone Wont produce a WIFI signal“.
Do you mean that you do not see the drone’s SSID in your mobile device’s WiFi connect utility?
basically, you first need to see if it produces a SSID signal. If yes, then is there an overlapping SSID WiFi signal that might be interfering with your drone-to-controller WiFi connection. Suggest you download one of the free WiFi analyzer apps to your mobile device (Android or IoS)
Hi Crossrich, thanks for the help!
Correct, i cannot see the drone SSID on any mobile device.
Will try the WIFI analyzer tool, do you have one you can recommend?
Thanks again
HongMunoz
