Return to Home Altitude
Air Raid
Anyone know how to change the Return to Home Altitude? I want to bump it up high to clear the trees.
No way to change it. 20m altitude counting from the take-off point. When you hit the RTH and the drone is lower it is going to get this 20m before start to travel to home point. If you are above 20m it is going to descent first.
Was never possible through FFPro app, but using telnet and editing reference.cfg. This breaks warranty.
That’s not true when you’re above 20 meters, it doesn’t going down first. It comes back at the altitude it is, and when arrived up to the home point, then it goes down.
Warranty? What's that? I've already got hacks (scripts to write to thumbdrive) installed. Would love to know how to change the default to 60m.
Ritchh
