Run Freeflight 6 on EPSON Moverio BT-300
enderffx
Hi, if you want to use your Anafi with the Moverio, i compiled a little howto.
Download the whole Archive here:
Run Freeflight 6 on Moverio.zip
Here is the howto:
Okay, running FF6 on the Moverio poses several Problems:
(1) The APp has an obb download, so simply copying or sideloading from APK does not cut it.
(2) The App has In-App Purchases that wont work with the internal Browser
(3) The APp uses Google Maps that needs the suiting Frameworks
(4) Strangely the App does not activate the onboard GPS
Solutions:
(1) Install APKPURE.APK from this archive.
Apkpure allows an install of the Freeflight 6 as apkx wich means the OBB is also installed.
THANK YOU APKPURE.
I am using apkpure as my main App Store on the Moverio by now.
New versions are there with only a day or two delay.
(2) Install Chrome, APK is included in this Archive
(3) Install all Google... APK from this archive.
(4) Cool enough but the GPSSampleForMoverio from the EPSON App store keeps the GPS on even when FF6 starts
Additional: You can install GPS Status, it allows A-GPS download (at home or via phone Hotspot)
Xou will need WiFi or phone Hotspot to cache Maps on FF6.
All solved, ENJOY :-)
ANd here is a screenshot of the archive contents in case you need to download the APK's manually. Forthe google stuff the exact version is IMPORTANT.
Enjoy,
Ender
Thanks this is awesome I am planning to buy Bt 350 I was wondering whether it would work with FF6 or not
Hi !
Good luck :)
A side note: i do not own the Moverios anymore.
When i tried to install FF6 on various exotic platforms i learned a trick with the latest versions:
Latest versions sometimes are not able to initialize their Data.
a simple workaround is to install an old version of FF6, run it and answer all questions, THEN upgrade the APK to the latest FF6 and voila!
So if in doubt try that :)
Good luck !
Ender
P.S. i only know my ways about the BT-300, not about the BT350!!!!
Here is the howto:
Solutions:
THANK YOU APKPURE.
All solved, ENJOY :)
Enjoy,
Ender
Hi Enderffx, I can not download the archive because it says it is no longer present. You can send another link. Thank you.
You are welcome, did it work out well ? I'd like to know as i am obviously unable to try on latest BT-300 FW & Freeflight...
Please let me know so i can forward to others waiting to try.
Ender
Hello Enderffx, your suggestion was successful, now I can drive the Anafi with Moverio BT 300. Even if sometimes Moverio BT 300 turns off and automatically restarts. On the list I was not able to install "google account manager", or tried several times but I can not, for the rest as well as with DJI phantom 4 pro.
Great experience Moverio BT 300, thanks again.
Here is the howto:
Solutions:
THANK YOU APKPURE.
Enjoy,
Ender
Here is the howto:
Solutions:
THANK YOU APKPURE.
Enjoy,
Ender
Hello
I was wondering if you had the latest version of archived contents that I could use for
Here is the howto:
Solutions:
THANK YOU APKPURE.
Enjoy,
He
Here is the howto:
Solutions:
THANK YOU APKPURE.
Enjoy,
Ender
Hello is there any way you could send me the Moverio Free Flight 6 zip file? Or point me in the right direction? I'd really appreciate it....... Marc.............. Puma176
Here is the howto:
Solutions:
THANK YOU APKPURE.
Enjoy,
Ender
I'm still having problems getting my BT 350's to work with my Parrot Anafi.... I'm missing something. Please help!!!😫
  • Wow
Reactions: edwardfcy1970
Hi Enderffx, would you be so kind to PM me the archive, as the link has expired., Some of those APK's in the image are much newer versions around.
Also what build of FreeFlight 6 did you use.
I would really apreciate it.
Cheers in advance
anafi76
