Hi, if you want to use your Anafi with the Moverio, i compiled a little howto.
Download the whole Archive here:
Run Freeflight 6 on Moverio.zip
Here is the howto:
Okay, running FF6 on the Moverio poses several Problems:
(1) The APp has an obb download, so simply copying or sideloading from APK does not cut it.
(2) The App has In-App Purchases that wont work with the internal Browser
(3) The APp uses Google Maps that needs the suiting Frameworks
(4) Strangely the App does not activate the onboard GPS
Solutions:
(1) Install APKPURE.APK from this archive.
Apkpure allows an install of the Freeflight 6 as apkx wich means the OBB is also installed.
THANK YOU APKPURE.
I am using apkpure as my main App Store on the Moverio by now.
New versions are there with only a day or two delay.
(2) Install Chrome, APK is included in this Archive
(3) Install all Google... APK from this archive.
(4) Cool enough but the GPSSampleForMoverio from the EPSON App store keeps the GPS on even when FF6 starts
Additional: You can install GPS Status, it allows A-GPS download (at home or via phone Hotspot)
Xou will need WiFi or phone Hotspot to cache Maps on FF6.
All solved, ENJOY
ANd here is a screenshot of the archive contents in case you need to download the APK's manually. Forthe google stuff the exact version is IMPORTANT.
Enjoy,
Ender
Here is the howto:
Solutions:
THANK YOU APKPURE.
All solved, ENJOY
Enjoy,
Ender
