Hi,
We have just returned from vacation. The drone had done a great job until the last day. Now the following happened, maybe someone knows advice.
In one of the last launches, I suddenly got no connection between the phone and the controller. Eternally tried around but nothing happened. All of a sudden - without the free light on - the Anafi wanted to rise to heaven, with full power. No chance to turn off the drone. So held in the hand until the battery was down. I suspect the drone would have flown elsewhere. Well, I assume that the Kopter as such should still be OK.
I have already read in the forum that the solder joints of the controller are vulnerable. And indeed, these are broken off. What makes me suspicious, however, is that when I push the USB cable to the solder joints, the smartphone is charged. However, the app does not start, even if I start the app manually, it does not find the controller. The smartphone is however loaded by the controller, so yes must be a connection.
Until the incident on vacation, everything has always worked out great. Controller unfolded, smartphone on and app started automatically .
