FreeFlight 6 and iPad Shortcomings....not optimised?
Anafi will set the home point when it acquires GPS at take off so make sure you wait for a good GPS lock; This will be the point Anafi RTH's too if required.
When you enter Follow Me Anafi will change RTH to RTM(Return to Me). In this case Anafi returns to the GPS coordinates of the GPS device attached to the controller which is very helpful if you are far from the home point. Without a GPS device you will lose this feature but you won't be following.
Also if you need to find your Anafi it's nice to have GPS on the controller/tablet so you can track down your Anafi on the map in relation to your position. I got the Mini 4 with GPS and barometer for follow, not only can I follow but I have dynamic altitude.
Reactions: Krusty Geeza
coadyread
