Help!!!
Wingy
I need a bit of advice, recently had a crash with Bebop 2, then couldn't get a signal from the Bebop, took apart checked all connections, no luck, but just happened to press the nose of the drone down a tiny bit and bingo the signal came back and all was normal until I took pressure off then back to no signal? could anybody give me some advice as to why this is happening. Please ?
Take a look at the camera ribbon area we’re it connects to the board, should be a small bracket pressed down on camera ribbon connection.
Check here,
Paul
Hi...what signal,video or wifi signal....if you can connect to bebop and fly but dont have video follow WaldoPepper instructions,try retighening the screws holding camera frame attached to board.....
If is wifi signal you are not getting,check the gps chip on top of the camera frame,on the side of gps is small ribbon cable that connects gps to pcb board,make sure its all way in and properly connected
Reactions: VonZipper
JohnnyJohn
