Low level battery warning
Fmaxii
Rennes - France
Hello,
I had a strange event this afternoon.
During the way back to the starting point, in RTH mode, there was a red warning in the bottom of the screen of FF6.
I could translate this way: Battery level too low, automatic landing will start in 12 minutes..
The battery level was stable, at 50%..
Yes, in 12 minutes ! What a warning ! 50% battery remaining is correct for a 12 minutes remaining flying time.
Anafi was about 20 meters high, descending to the starting point.
The Anafi battery was at 50%. The flight was less than 10 minutes long.
The SC3 was also at 50%.
I let my Anafi doing his way back to home starting point, without trouble, but still had this message.
I use the official app, in France, and maybe in fcc mode: I was manually at channel 165.
All softwares are up to date.
FF6 is version 6.6.7, Android phone.
Anafi is in version 1.6.7. Batteries were updated during last firmware.
So strange...
I’m not afraid with that, but I think it could be useful to post it, to know if other people had this message, or if a reason or even a solution is knowned.
Hello,
So strange...
Did you report this problem to Parrot Support ?
No, I didn’t. The drone was fine, I was able to control it.
I will try again in few days, when the weather will be less windy, to see if this message reappear.
Then, if it reappear, I’ll take a screenshot and will contact Parrot support
Yes that is a good attitude. A well-documented, well-documented complaint is worth more than a plain complaint. Photograph, video, flight log and detailed description of the event. This is needed and there is no dispute.
Hello,
Impossible.
In order to be in FCC mod, channels 36-48 must be displayed.
If they do not appear you are not in FCC mod
FF 6.6.7 appears on GooglePlay today or not?
How the hell is this happening?
With the official version;
Is it possible to have FCC in France?
I have FCC channels since FF6 Update 6.5.5 RC1, deployed in the beginning of february
But that's not the subject of this thread ;)
Ehm, I had this too, today!
And I had for 90% of the flight no distance.
Also today, different location, my "HP", better MY position "jumped".
Still trying to find out if A-GPS kicked in, perhaps my phone did loose the GPS position?
So strange...
Now we know that it’s not because of all last updates...
But it seems to be a new default anyway..
In both cases, it happened when Anafi was close to us. About 10 meters for you, maybe less than 20 meters for me...
It happened a bit before, actually.
But it was close by, 50meters or such and just a bit more up.
And stayed till it landed
Well... Same warning message today. It had appeared exactly when the battery level was at 50%.
How "old" are these batteries, year, cycles ?
My batteries are from 2018, they do have 40ish circles, I think
Also I am still on the "good" fw! So none of the 2020 updates did anything to my bird.
And today I had 2 flights with no problems, no messages.
I have to admit, it could have been the 3. battery.
Have to check on that
