Thanks to pete2k from Finland, I think I figured out some issues on how to process the panos after they have been taken. Looks like Parrot wants you to use the Media center on the FreeFlight 6 app for processing the pano’s that were taken. Essentially, you need to transfer the contents of your Anafi SD card to the device that contains FreeFlight 6 app. You do this when the two are connected. Once I figured this out (thanks again to our Finland friend!) it was relatively easy to create the pano’s in the FreeFlight app in the Media section using your device (mine is a Android Huawei Mediapad). Once in the Media section, you click on a Pano and it will give you options to create the final pano in either normal resolution or high resolution. That is where the Tunnel and Little Planet options are located if you click on a 360 degree pano. Below are two examples of a Little Planet and Tunnel pano options created from a 360 degree pano. Plan to do a bit more testing this weekend – assuming weather cooperates in Chicago. BTW, in my opinion Parrot should release new written instructions when a major update like this is released.
View attachment 624View attachment 625
