New firmware update Anafi 1.6.7
First flight with 1.6.7 and at landing was crash from 80 meters at 26 % capacity of battery - after crash was one led steady green, not flashing. I was lucky because nothing happen with the drone. I was continued with other two batteries with landing at 25% and 35 % without any crash. p.s. never any crash with this drone before.
This is another proof that 1.6.7 1.6.5 and 1.64 has the CE lock to another country and confuse's the drone elevation , and the batteries update is limiting power for the frequencies strength and making the motors lose power beyond firmware recovery
?? Unfortunately, That post doesn't make much sense.
Reactions: MustangPhil
hi everyone, i'm new to the group but i have been following you for a while, i also noticed that something has been changed, in fact i can't use the FCC mode, i attach photos of my configuration, i must say that it bothered me a lot realize that you can no longer use this mode, not for long range, but to have a more robust and reliable signal in particular conditions, however now it is a problem, you should make programmers understand that this is an important factor, FCC mode makes the safe and reliable signal especially in areas with a lot of wifi interference (which could create problems) ... in this configuration I violated for over 15 minutes (of course THERE IS MODE ... unfortunately) but ANAFI flew without problems ... I downgraded the app from 6.6.6 to 6.6.2 using fake GPS and installed everything without satellites. just turned on the TX and smartphone on the wifi signal I noticed that when I turned on the drone for a few seconds FCC MODE appeared, but only a few seconds, then automatically and returned to CE mode. I'm sorry to provide only this as information but I hope it will be useful ... at the end of my test I installed the latest version of the app (which however does not affect the firmware of the drone and the tx command) at moment I don't upgrade the firmware 1.6.7 but use only 1.6.5 how I show in photo... wait news...sorry I'm in Italy
POST : Freeflight 6 mod app
Read as much as you can
I wish you and your country the strength to resist the attack of the coronavirus . ✌
Reactions: Tornado and gibbi
[QUOTE = "gibbi, post: 31617, membro: 5649"]
appena acceso il TX e lo smartphone sul segnale wifi ho notato che quando ho acceso il drone per alcuni secondi è apparso FCC MODE, ma solo pochi secondi, quindi automaticamente e sono tornati alla modalità CE. Mi dispiace fornire solo questo come informazione, ma spero che possa essere utile ... alla fine del mio test ho installato l'ultima versione dell'app (che tuttavia non influisce sul firmware del drone e sul comando tx) al momento non aggiorno il firmware 1.6.7 ma uso solo 1.6.5 come mostro in foto ... attendi notizie ... scusa, sono in Italia
[/CITAZIONE]
Ciao anche io dall'Italia ho provato con un Note 8 a cambiare la lingua con quella degli Stati Uniti poi ho installato FF6 6.3.0 poi con Fake gps negli a NY mi ha dato FCC solo qualche secondo poi è tornato in CE.
Fammi sapere se hai novità !!!!
Io stò in Sardegna qui il Virus è ancora sotto controllo ma sempre in aumento!!!!!
TE = "gibbi, post: 31617, member: 5649"]
just turned on the TX and the smartphone on the wifi signal I noticed that when I turned on the drone for a few seconds FCC MODE appeared, but only a few seconds, then automatically and they returned to CE mode. I'm sorry to provide only this as information, but I hope it will be useful ... at the end of my test I installed the latest version of the app (which however does not affect the drone firmware and the tx command) at the moment I do not update the firmware 1.6.7 but I only use 1.6.5 as a monster in photos ... wait for news ... sorry, I'm in Italy
[/QUOTE]
Hi also from Italy I tried with a Note 8 to change the language with that of the United States then I installed FF6 6.3.0 then with Fake gps in NY he gave me FCC only a few seconds then he returned to CE.
Let me know if you have any news !!!!
I'm in Sardinia here the Virus is still under control but always on the rise !!!!!
like
Here in Germany I had never FCC and this mode was never allowed here. So I don't miss anything. ?
Same for Italy, as far as I know....
Have to say after several flights that the update seems to work well now. No crashes or flaws that I faced....
So I was travelling with none of my Anafis when the update that included battery firmware rolled through. I have seen conflicting reports so didn't go for it since I wasn't flying when I got home. My question is do I now do the latest craft and controller firmware update but leave the batteries on the original firmware?
Thanks folks,
Dan
Based on all the reported problems over the last few months, if I had a working firmware (like 1.63) I would not update. I can't see that any of the updates after that one bring any wonderful new features to the table that would make it worth the risk.
Thanks Rocky. That's kind of where I was getting to. Not sure if it will let me but I'll charge up and see.
gregholmes2696
