This Anafi is my first drone so I am still trying to figure out how everything works, is the elevation reading suppose to change with the contour of the ground if you are flying on a horizontal plane, mine does not if I fly from the top of a hill strait out it reads the same elevation even though the ground slopes down increasing the distance from the drone to the ground, is this right or do I have something not set up right, I would think it should read distance from the ground as the contour changes.
