Parrot Anafi Available for Trade
rsvibhadaniya
I am Ravi From India, anybody having anafi and want anyof these parts please contact me,
i want to trade Parrot Anafi with 3 Extra Batteries ( Total 4 Battery, )
i had a serious crash 3 time with Smart Battery S/N C8H209645 ( this battery is problematic one , it cuts power around 35 to 30 % battery level and drone crashes). And ANAFI Gimbal L-Bracket is slightly bent which is preventing camera to stabilize. In crash Anafi front Right Arm and Back Left Arm was cracked and it is fixed with Industrial Glue.
Defactive parts
1. Gimbal L-Bracket Bent Slightly
2. Smart Battery S/N C8H209645 (purchased with drone)
Fully Functional Parts
1. Smart Battery S/N C8H160628 (Came with Drone)
2. Smart Battery S/N C8K299301 & C8K299825 ( Purchased on 7th May 2019 from Aliexpress,Both Battery is not Used more then 20 Cycles)
3. SkyCcntroller 3 S/N PI040443CA8H100373
4. ANAFI S/N 8I096725 ( 4 Motors and all sensors working Except Gimbal )
5. And all Box contents (USB-C Cable, 16 GB Micro SD, Tool to change Props, extra Props, Drone Case)
Drone Purchase Date 13th Nov 2018
for Battery and drone Checkup i am Also giving Full Flight Data.
Here is some photo of Drone , battery and defective pars attached.
any body interested in any of these item please message me.
I have problem with the drone.. I am not able to connect it to the controller. suspect the motherboard or the gps module has malfunctioned. My controller and the batteries are all fine. also the gymbol and the camera seems to be fine visually.
Iam from india and iam not able to get the drone repaired as the spare parts are not available anywhere.
Eu sou Ravi da Índia, qualquer pessoa que tiver anafi e quiser alguma dessas partes, por favor, entre em contato comigo,
quero trocar o Parrot Anafi com 3 baterias extras (total de 4 baterias)
Eu tive uma falha grave 3 vezes com a bateria inteligente S / N C8H209645 (esta bateria é problemática, ela corta a energia em torno de 35 a 30% do nível da bateria e o drone falha). E ANAFI Gimbal L-Bracket é ligeiramente dobrado, o que impede a câmera de se estabilizar. Na colisão Anafi Braço Direito e Traseiro Esquerdo estavam rachados e fixados com cola industrial.
Peças desativadas
1. Suporte em L do cardan ligeiramente dobrado
2. Bateria inteligente S / N C8H209645 (adquirida com drone)
Peças totalmente funcionais
1. Bateria Inteligente S / N C8H160628 (Veio com Drone)
2. Bateria inteligente S / N C8K299301 e C8K299825 (adquirida em 7 de maio de 2019 na Aliexpress, ambas as baterias não são usadas por mais de 20 ciclos)
3. SkyCcntroller 3 S / N PI040443CA8H100373
4. ANAFI S / N 8I096725 (4 motores e todos os sensores funcionando, exceto Gimbal)
5. E todo o conteúdo da caixa (cabo USB-C, Micro SD de 16 GB, ferramenta para trocar acessórios, acessórios extras, caixa do drone)
Data de compra do drone 13 de novembro de 2018
Para verificação de bateria e drone, também estou fornecendo dados completos de voo.
Aqui estão algumas fotos do Drone, bateria e pars defeituosos anexados.
qualquer corpo interessado em qualquer um desses itens, por favor me envie uma mensagem.
boa tarde ainda tem disponibilidade?
Я Рави из Индии, любой, у кого есть анафи и хочет что-нибудь из этих частей, пожалуйста, свяжитесь со мной,
Я хочу обменять Parrot Anafi с 3 дополнительными батареями (всего 4 батареи)
У меня был серьезный сбой 3 раза с Smart Battery S / N C8H209645 (эта батарея проблемная, она снижает мощность примерно на 35–30%, и дрон дает сбой). L-образный кронштейн подвеса ANAFI слегка изогнут, что мешает стабилизации камеры. При аварии Anafi передняя правая рука и задняя левая рука были треснуты, и они закреплены с помощью промышленного клея.
Неактивные части
1. Г-образная скоба карданного подвеса слегка изогнута
2. Smart Battery S / N C8H209645 (приобретается вместе с дроном)
Полностью функциональные части
1. Интеллектуальная батарея S / N C8H160628 (поставляется с дроном)
2. Интеллектуальная батарея с серийным номером C8K299301 и C8K299825 (приобретена 7 мая 2019 г. на Aliexpress, обе батареи не используются более 20 циклов)
4. ANAFI S / N 8I096725 (4 двигателя и все датчики работают, кроме кардана)
5. И все содержимое коробки (кабель USB-C, 16 ГБ Micro SD, инструмент для смены реквизита, дополнительный реквизит, футляр для дрона)
Дата покупки дрона 13 ноября 2018 г.
Для проверки аккумулятора и дрона я также предоставляю полные полетные данные.
Вот фото дрона, аккумулятора и неисправных частей.
любой орган, заинтересованный в любом из этих пунктов, пожалуйста, напишите мне.
NShi, i'm ready to buy. What is the cost?
stefaz72
