Problèmes spherical panoramas 360 * 180
gilles
I try to realize 360*180 panorama with my Anafi
I have a iPhone 5S in the skycontroller
The anafi, at 20 meters, in static fly, 0 m/s wind, but the anafi move a lot, 3 or 4 meters in all directions
I calibrated again the drone yesterday
I can't stitch the photos with PtGui
I have the last update software
Thank's for your help
(sorry for my english)
Gilles
There was no wind, even at 20 meters. The trees didn't move
I think PtGui is the best software to stitch photos, really better than Autopano Giga
I use Canon 5D Mark III or IV, fisheye 8-15mm, pano head Ninja every day to create virtual tours.
That's the reason I bought an Anafi, to create panos
If the Anafi move, the shots are wrong, not at the 'nodal point'...
I don't undertand why Anafi move without reason
1st point here, the Anafi does not & never will move on the nodal point. It rotates sort of around its centre most part. For elevated 360 panoramas where you don't have anything too close, minimum of 4 metres away, you won't notice any difference.
Regarding such severe movement, there must be something electromagnetic interfering somehow. Are you flying with your mobile phone or tablet on Aeroplane mode? Have you done the same for a smartwatch, or any other devices you may have with you?
Have you waited a good 30 seconds after getting the green lights for GPS on both devices before flying? I wait about a minute after that before flying & get maybe 20 cm of shifting around at most.
Gilles
An advice. Make sure Anafi's camera is aligned with the horizon before attempting to make a panorama shot. Then the stitching program has the easiest by gathering the pictures without any errors.
The last time I made a panoramic shot, Anafi stood at the same point all the time and turned around.
Skúsili ste spojiť fotografie v FF6? Urobil som desiatky panorám a nikdy som si nevšimol, že sa pohybujú tak, ako ste popísali. Je možné, že vo výške 20 metrov prevládal nárazový vietor a na zemi nula.
Na zemi som zaznamenal pokojný vietor a vo výške FF6 som dostal výstrahu pred silným vetrom.
FF6 spája len do malej panorámy - vhodné na sociálne siete - ak potrebujete veľkú panorámu - potrebujete použiť iný program - tiež mám problém s ANAFI - prečo software Parrot nevie urobiť veľkú FULL 360x180 panorámu? to je otázka na parrot
Biohazard
