I have been designing a second mount for my Anafi's (for rear facing or auxilary front view). I have tested the Insta360 G2 , RunCam 2, Mobius Maxi and lastly the DJI Action 2 . I couple of notes:
1-The Insta360 G2 has a lot of vibrations transmitted to video - nice shots for stills not motion (on drone)
(Does great job if you use post process app however, vibration is still there)
2-The RunCam 2 4K and the Mobius Maxi 4K work, nice video however, stability is poor. You do not see the vibrations you see with Insta360 G2 just camera woble and horizon shift
3-The DJI Action has excellent video stabilization and quality the problem is when mounted 1.5" above battery the Anafi will loose front to back stability because of CG .
4- I have a new lower profile DJI Action 2 mount that drops camera 1.5" to .1 above battery will test as soon as weather clears up
5-The higher mount works great for lighting as pictured
I will post video ASAP
This may seem like a waste of time however, I use my Anafis 10x more then my DJI Mavic Enterprise, Skydio 2 and Yuneec H series drones
