"strong WiFi interference" fixed (?)
AlexZh
After installing updates, I always make the first flight in a place where there are no trees, wifi, interference, electric lines.
Today, during the first flight after updates at a distance of 110 meters, I received a message on the screen "strong WiFi interference".
I already had this situation in October, and I repeated the decision that helped me then
I returned the drone, calibrated only the drone, the next flight was OK, there was no interference, the maximum distance was 600 meters
The problem is not interference, but in the calibration of the drone?
I get this same message erratically. I calibrate before every flight & even after a battery change. It even happened at the beach, where there are no houses or electricity for about 1 Km & the nearest cell phone tower is about 2 Km away!
Next time I experience it, I'll try recalibrating the Anafi & see what happens.
You probably are aware already but I wasn't, be certain to turn Airplane Mode on, so the phone's cell band will not cause any interference. That is not why you got the message, but it is just one more source and they are cumulative.
Reactions: pmh1nic
heti
