Thanks for testing.. you're quite braveDid the firmware up date. No problems with the test flight. GPS seems just as fast as it was before, at least for me. My problem with the follow me mode seems to be corrected. The camera now stays on subject instead of dropping straight down. The up and down movement is still there in follow me but I can live with that.
Again another firmware that only fixes the previously working but then corrupted functions and capabilities ...Did the firmware up date. No problems with the test flight. GPS seems just as fast as it was before, at least for me. My problem with the follow me mode seems to be corrected. The camera now stays on subject instead of dropping straight down. The up and down movement is still there in follow me but I can live with that.
No GPS on your Tablet or Phone?Sorry I lied it was 2.2KM
People crying about CE mode should really... STFU
(stay transmitting flying unobstructed)
It happens when I put it on airplane mode before starting the appNo GPS on your Tablet or Phone?
Airplane mode means you turn off all radio transmissions (WiFi, GPRS, Bluetooth, NFC).It happens when I put it on airplane mode before starting the app
edit: that’s weird I reviewed the screen recording and the controller GPS returns during the flight
I have this happen sometimes too, usually when my wifi signal is weak - seems that GPS on phone turns red & occasionally on droneIt happens when I put it on airplane mode before starting the app
It seems Parrot really hasn't been able to release a flawless firmware since 1.6.3:Again another firmware that only fixes the previously working but then corrupted functions and capabilities ...
Meanwhile, the tracking is not perfect, The mission stops at waypoints, the BMS does not follow the aging of the battery well, gimball initialization often only works on the second start,
I'm still sticking with the 1.6.3 firmware ... because FCC mode has always worked, I've always found GPS quickly, the panorama has always worked well, the app has always been stable, never switched to 1080p - re after reboot ...
