Hi Paul
I know once you buy it for the Android systems you can have it on as many phones and or tablets that you like. Not sure if iOS works this way but I would think it should. Worst thing that can happen is it tells you to buy it again.
Hello Agustine,
Thanks for sharing with an Android system it’ll work with many phones and tablets, I didn’t know that. When my iPad/iPhone service contract expires, going back to Android and by then I’ll have a computer as well.
Yesterday, with the Anafi flew another flight plan was easy to setup and this time got a little more daring creating a flight path flying between large oak trees and thick foliage. Then, as the Anafi is maneuvering though this foliage and trees it’s maneuvering over a river. I’m going to enjoy creating more flight paths in the future, endless possibilities very exciting.
Also attached a small tracker to test out, the Anafi can handle small weight but it will definitely shorten Battery life, this tracker knocked off about 6-8 minutes of flight time but had no problem carrying the tracker Anafi maneuverable was still great.
When I was done exhausting three Anafi batteries, wanted to try the flight plan feature with the Mavic 2 Pro. One thing I found out quickly, the Anafi flight plan feature is much easier with the Anafi and doesn’t require the controller or drone to be on. With the Mavic 2 Pro, drone and controller need to be on and drone be hovering, once the M2P was hovering I could open the flight plan feature and create a flight plan, that’s that down fall of Mavic 2 Pro flight plan the drone needs to be hovering which burns up battery.
Luckily, Mavic 2Pro Battery has a long flight time but still was disappointed couldn’t create a flight plan with the controller and drone off as with the Anafi flight plan app. But after creating the Mavic 2PRO flight path with its way points it flew great no problem was very good and enjoyable to use.
I’ll attach couple of pics with the Anafi carrying the tracker, occasionally I use this tracker on my Bebop 2 and Mavic 2Pro on long flights when disconnects can occur. Three times, it’s saved a Bebop 2 landing further away from its last known connection.
Thanks again for the informative help!
Paul
