Anafi vertical camera displaced
Regling
Hi all,
I just received my new Anafi and did a couple of test flights without issues.
What bothers me and I was wondering is this a defect - looking at the vertical camera at the bottom - it is not centered in the opening so if there are vibrations it could touch the shell.
Is this normal?
I have two Anafi’s and on both the camera is in the same position as yours. One of my Anafi’s was acquired as a “Spares or Repair” so I did a complete strip down and rebuild and still the camera is in this position. It can’t be moved as the internal mounting points for the PCB prevent this.
I hope this quells any fears you may have had.
Regards
Nidge.
Regards
Nidge.
Thank you so much for the response!
Reactions: tmgrood
clansman320
