- Joined
- Sep 27, 2018
- Messages
- 30
- Reaction score
- 17
- Age
- 41
- Location
- Canoas, Rio Grande do Sul, Brasil
- Website
- www.rafafischer.com
I just have received an alert on my Freeflight and it's showing a update do 1.2.1 to 1.2.4, anyone hava a changelog?
Are you guys on iOS? I'm not seeing the update at Google Play store.
Release Notes Firmware V. 1.2.4
Sorry Parrot, but ................. After trying two different routes in flight plan, I can observe that the camera closely follows the direction of the different POI's but not the height.That means you can fly over a POI at at the ground level with the camera pointing 90 degrees in the air !!!
After playing HDR, I can see that camera zoom does not work in 4k. It is possible to zoom in 1080p but the image becomes very blurred.
Conclusion: Unfortunately, the last firmware is two step backwards, not forward !!!
Regards Leif.
So are you saying the camera angle does not change to the POI? I will be flying a little a later on so I will also test and report back.
I have seen posts on Anafis Facebook page where tests where done and they said it worked perfectly but I will test later.
OK so very short flight with one POI and two waypoints hooked up to the POI. The Anafi was at 250 feet and the POI was set to 10. The camera adjusted the angle to the POI as it should have. The zoom on HDR is not there. I do not remember if it was on the older firmware but it is not there now thats for sure. It is 12 degrees F this morning so it was a bit cold but the Anafi performed well in the cold. View attachment 511
Finished uploading the video to youtube from my POI test. Everything seems to be fixed. I did notice some jerky video as the Anafi was returning home but the video from the SDcard was not jerky so something must have happened during post processing the video to Youtube.
The POI was home plate at the baseball diamond.
12° F and the Anafi performed just fine. 6:04 flight time and the battery was at 75% when landed.
I think I was colder then the Anafi
Well considering it was only 10 feet off the ground I really don't know what your looking at for a horizon [emoji3]Agustine, is it me or your video does feature a ‘not so horizontal’ horizon line ?
Philippe
