Yes. Please create a custom flight plan manually, save it, and upload an archive with a folder of this plan in response to my message. On Android devices, the flight plan is saved in a folder with the name you assigned to the plan. I hope it's the same on iOS devices.
I will study the differences and make a version for iOS.
Android saves flight plans here: "/sdcard/FreeFlight 6/flightPlan/..."
From what I remember about the iOS system unless you have a jail broken phone or tablet you cannot access the file system like we can with Androids. Perhaps things have changed but Apple never wants people fooling around with their file system.
It seems the Flightplan is in a folder ".contents"
I attach the folder here.
Thanks !!!!
  • FlightPlan.zip
    FlightPlan.zip
I use Itools pro and I can read import and export any files without a jailbreak iPhone... but its not as simple as Android :cry: !!!
Thanks !!!!
Thank you!
The flight plan for iOS contains one more file. The purpose of the data in this file is not clear to me, at least some of the lines are not clear at all. Could you create several one more (2-3) such arbitrary flight plans? This may help me understand the meaning of this data.
(added later) I found a description of this data. If someone is interested - here is the link: GroundSdk FlightPlan Documentation — MAVLink-flightplan 1.2.0 documentation
Thank you!
Hi,
I have created 2 other FP and you can see 2 new folders are created with in each one 3 files ..
Reactions: abant
This is a test page that creates two archives: the flight plan in Android format and iOS format. I don't have an iOS device, so I ask volunteers to check if this data can be read by FreeFlight6.
(y)Yes it works for me !!!! but I can't fly because .... covid ...
The only problem is that we can't see the" miniature "of the FP in the library, but I think there is an other file in an other folder ..
Thank you
Reactions: abant
Thank you
Same thing happens on my Android phone but if you make an adjustment to it and then save it again picture will be there,
Reactions: pa911
Thank you
Have you saved it again, after loading it?
On my Androids it is also 'blank', at first sight. But after saving, it takes the miniature pic from the FF6
Thank you
The miniature with the map and WP is created when the freeflight 6 program saves the flight plan. When creating a flight plan on the site, the miniature is created using the name of the flight plan. You can, for example, change the POI height after loading the flight plan and save it. The miniature with the text will be replaced with a normal one.
Reactions: pa911
I hope that one of the users of iOS devices will be able to perform the flight and report the result. If everything is OK, I will transfer this functionality to all pages.
The big problem is to access to the ".contents" folder .. I have used an old release about Itools but ... it's not free !!! and with Imazing or iTunes, no success ..
Thank' a lot for your work
Rectification : It works with Imazing !!!!
It is not difficult for Parrot programmers to add a tool for importing and exporting flight plans to the program. I think that if enough users would contact them with such a wish, they could include it in their work plan.
I'am Ios user too, il will try soon and tell you how is gone. But very amazing job ! well done guy.
So after the first test, it's work but i have a speed problem. I have a constant 2m/s and sometimes increase to 3m/s.
The flightplan is between 30s and 1.30s.
Reactions: abant
Patrick2A
