Trying to use the the updated version of your page @abant I am having trouble with adding any of the other options. If I add a spiral and click insert nothing happens. Also I liked it better when we could click show to see which direction it would start at. To many changes is sometimes not good. Also Imperial and metric are still have issues. You cannot set anything in Imperial past 120 feet which is the max on the metric page.
I can't check everything right now, but adding elements (points, orbits, etc.) works correctly.
So i am a bit of a dummy when it comes to iPhones-
I am trying to figure out how to get the flight plan into iphone from PC
So I assume you connect iphone to PC - find the correct directory on phone and extract files from PC into that directory
However I have have not been able to find that directory on phone
What am I missing?
What am I missing?
Start reading around post #123. One of the members uses a program called Itools pro to transfer files. I am not a iOS user so I cannot offer any help.
Reactions: BRC
I can transfer files from a Mac or an iPad to my IPhone with iTools Pro or Imazing but as I have no PC I can't help you ... I have seen iTools Pro is Windows compatible , perhaps you can use it ?
OK I was assuming when you click "insert" it would insert it automatically. Thanks for the video help.
I don't speak English, and Google.Translate sometimes lets me down.
I copy information about how to use the app from the forum to this page. In particular, the situation that caused the difficulties is described in paragraph 8, but I'm not sure that the text is clearly translated into English, and that it is complete. I would appreciate an indication of the errors that need to be corrected.
As for errors with height and speed limits, I will fix them soon. With all my efforts, I can't find all the bugs before the release, unfortunately. Thank you for letting me know.
And added a small change.
Since this is a global parameter that affects all elements, it is moved from the " Values of WP" window to the main window.
Thank you.. iTools Pro works with windows pc to transfer files to iphone
New functionality. Added file creation log.txt, which contains information about the flight plan in an easy-to-read format. The file is archived with the flight plan. Example:
Code:
test2, 06.22.20 07:58:38. Lat: 38.5807056, Lng: -0.1365604 0.305
Takeoff: Start video capture, Tilt: 30, Ang. speed: 10º/s
WP 1. Lat: 38.580466, Lng: -0.137022, Alt (f): 20, Speed (f/s): 4
WP 2. Lat: 38.580627, Lng: -0.136987, Alt (f): 20, Speed (f/s): 4
     Pause: 5s
WP 3. Lat: 38.580743, Lng: -0.136907, Alt (f): 20, Speed (f/s): 4
     Tilt: 80º, Ang. speed: 10º/s Pause: 5s
WP 4. Lat: 38.580803, Lng: -0.13667, Alt (f): 20, Speed (f/s): 4
    Start image capture. Interval: 3s, Format: DNG Pause: 5s
    Start image capture. Interval: 6s, Format: DNG
    Start image capture. Interval: 10s, Format: DNG
WP 5. Lat: 38.580839, Lng: -0.136481, Alt (f): 20, Speed (f/s): 4
    Start image capture. Interval: 5s, Format: JPG WIDE
WP 6. Lat: 38.580869, Lng: -0.136253, Alt (f): 20, Speed (f/s): 4
    Start video capture Pause: 5s
WP 7. Lat: 38.580745, Lng: -0.136182, Alt (f): 20, Speed (f/s): 1
WP 8. Lat: 38.580706, Lng: -0.136348, Alt (f): 20, Speed (f/s): 1
     Pause: 5s
WP 9. Lat: 38.580668, Lng: -0.136514, Alt (f): 20, Speed (f/s): 1
WP 10. Lat: 38.580676, Lng: -0.136881, Alt (f): 20, Speed (f/s): 10
WP 11. Lat: 38.580771, Lng: -0.136462, Alt (f): 20, Speed (f/s): 10
     Pause: 5s
WP 12. Lat: 38.580888, Lng: -0.135925, Alt (f): 20, Speed (f/s): 10
WP 13. Lat: 38.580711, Lng: -0.136484, Alt (f): 20, Speed (f/s): 1
     Tilt: 0º, Ang. speed: 5º/s Pause: 5s
     Tilt: 60º, Ang. speed: 30º/s Pause: 6s
     Tilt: 0º, Ang. speed: 60º/s Pause: 7s
WP 14. Lat: 38.580559, Lng: -0.136829, Alt (f): 20, Speed (f/s): 1
WP 15. Lat: 38.580587, Lng: -0.136522, Alt (f): 20, Speed (f/s): 10
WP 16. Lat: 38.58068, Lng: -0.136169, Alt (f): 20, Speed (f/s): 1
WP 17. Lat: 38.580928, Lng: -0.136188, Alt (f): 20, Speed (f/s): 1
WP 18. Lat: 38.580668, Lng: -0.136299, Alt (f): 20, Speed (f/s): 1
WP 19. Lat: 38.580868, Lng: -0.136424, Alt (f): 20, Speed (f/s): 1
WP 20. Lat: 38.580884, Lng: -0.136332, Alt (f): 20, Speed (f/s): 1
    Start image capture. Interval: 3s, Format: DNG Tilt: 30º, Ang. speed: 10º/s
WP 21. Lat: 38.580941, Lng: -0.136285, Alt (f): 20, Speed (f/s): 1
    Start image capture. Interval: 3s, Format: JPG WIDE
WP 22. Lat: 38.580925, Lng: -0.136446, Alt (f): 20, Speed (f/s): 1
WP 23. Lat: 38.580906, Lng: -0.136569, Alt (f): 20, Speed (f/s): 1
It is recommended for use when analyzing the captured video material.
Reactions: zandoli and pa911
Hello Abant-
I tried to register on your website yesterday -
Said I would need to confirm email via link being sent
I never received an email?
Thanks for your help
Hello Abant-
Could it have been redirected to a subfolder? Gmail, for example, assigns a "Notification"tag to these emails. I will activate your account manually.
cloud9rc
