Someone will eventually find a way to use jtag on the Anafi, remove problematic firmware and flash modified firmware
Well volunteered that man ?
Lets face it, you cannot do any more damage than what Parrot has done with these latest releases. Lets see what jewels they have in 1.6.7
Reactions: catkinson80
Does anyone have any idea of what the pinouts are for the bank of 8 pins between the battery and the Anafi ?
Logically, they also have a USB, 4pc connection, because you can download the contents of the SD card by connecting the battery to the computer.
today no gps on controller. reset, reinstalled, recalibrated and tried several times. Done shows 17. Yesterday no problems.
If you don't have wifi+cellular model then no you do not have a GPS.
Standard Ipads don't come with GPS.
You need a after market GPS hooked up through bluetooth for it to work. So any Android device would be better
Well maybes it is related to your particular tablet then ?
I thought only the really early iPads had no gps but I must confess I don't know a great deal about iPads.
Is your pad showing GPS, other apps, not the A-GPS apps, but real sat apps?
I guess going back to android. My question is do I reset controller and drone before I connect the Nvida Shield?
I like the Ipad because of the better screen. I have run my P4 and Mavic 2 with no problems.
Yes for each battery you have just turn off the Anafi, and insert the new battery and turn it on. Plug in the USB-c cable to that battery and it will tell you it needs updating. Do this for each of your batteries.
Agustine,
I used this instruction with 3 batteries that have sat around here for 9 months.
I plugged the USB-C into the battery and the other end was in a battery pack power supply.
Some doubled green flashing and then red flashing that stopped after a few seconds.
Is this the sign that the batteries' firmware was updated?
D2
Ok. Got it set up and BINGO GPS Thanks everyone.
Patrick2A
