Why is parrot not publishing software version on either the freeflight official website or freeflight 6 googleplay?Yes for each battery you have just turn off the Anafi, and insert the new battery and turn it on. Plug in the USB-c cable to that battery and it will tell you it needs updating. Do this for each of your batteries.
It just seems to be true that "updated March 4, 2020"
This can be the way to push all and everyone into the latest software!WOW
Never seen this before. Making you do a battery update also.
Each battery needs to be updated. It takes a little while and the battery needs to be plugged into a power supply.
I wonder if this will take care of the sudden power drop some have experienced?
One big complaint going around in the groups on facebook is you need to have a Wi-Fi connection or you cannot start FF6 in airplane mode. Not much of a problem as you can turn that on after startup but some people use phones without a Sim Card. ?
A good test, if the new fw on batt and bird work with an older appThank for stating this - I thought I was going mad!!!
It is a bug, it keeps doing the Data Synchronzation on every startup. It is downloading 250MB of data everytime it starts, and it will not continue if there is no internet connection.
I will go back to 6.6.5 till they resolve it.
