No Wifi Detected From Drone
Chicken Wings
OK, so I got the app installed, turn on sc3, connect phone, update sc3, go to update drone, no wifi from drone. Read the posts about this prob, try hard reset, still nothing.
I see the "connect automatically" with sc3 and drone connected by wire and "connect manually" with "enter wifi password", hit button, "select drone from list", -
"no drone detected". Any comments on connecting controller and drone by wire or how to get drone wifi running?
1. Smartphone in Airplane Mode (Wifi, 3G/4G, BT off)
2. SC3 and smartphone connected with USB cable
3. FF6 should run and display SC3 box green
4. Anafi switched on, should auto-connect to SC3
As you describe, points 1 to 3 are functioning.
If only 4 is not ok, then check, if there is an Anafi Wifi:
1. Smartphone Wifi on
2. In WLAN settings look for an Anafi Wifi entry in your Wifi spots list.
If there is no Wifi of Anafi on one of the 2 bands (5 GHz, 2.4 GHz), there may be a hardware problem.
Reactions: Chicken Wings
phildart
