Jagerbomb52
I would not put it on any part that needs to contact other parts. No point in that. As for covering your drone with it LOL its pretty darn expensive stuff. Have seen the size of the bottle and the price
True true but if you get it on like with a small paint brush and only have to do it once ever then that is all you need right for the entire drone? Plus it is water proofing it and the gimble.I would not put it on any part that needs to contact other parts. No point in that. As for covering your drone with it LOL its pretty darn expensive stuff. Have seen the size of the bottle and the price
That is pretty dope.No it will not help doing it that way, some parts will not benefit from that IMHO.
I will add to this conversation that the Anafi is a pretty tough little bird. As some know my first one spent 3 months up in a pine tree during the Canadian winter. There where rain storms and ice storms near the end before I found it. The day I found it it was a nice sunny day. Brought it into the house and placed it in front of the heat vent to help dry it off although it showed no signs of moisture. About a hour later it fired right back up. It had video but no control for gimble. That proved to be a bad ribbon connection that I solved later on. It still flys like it was new.
Ah i see. But in theory you could brush this on the entire drone...like directly into those motor housings without taking it apart.?There are plenty of Youtube videos on the subject. This guy has several products out on his table that will work but goes through them and tells why he does not like them over some others. The ESC's are your main spot you want to coat. The Anafi's ESC's are part of the board so you would have to take the boards out to fully coat them to have any good effect. You also want to be careful around the camera. You don't want this stuff on your camera lens
I would not put any conformal coating that sets up hard in the motors. CorrosionX would be OK. The brushless motors are not bothered by water.Ah i see. But in theory you could brush this on the entire drone...like directly into those motor housings without taking it apart.?
Good to know. thanks.I would not put any conformal coating that sets up hard in the motors. CorrosionX would be OK. The brushless motors are not bothered by water.
I see.I applied Corrosion X to my Anafi battery leads,motors and small cavities throughout the Anafi last September upon purchasing the Anafi.I used a product called Faderlube F5 on the connectors to lubricate them as well.I have not noticed any problems,but I tend to avoid rain regardless.
Please keep in mind this is my PERSONAL experience.Do your research and go with a product you are comfortable with.
Ok! ?I have a water proof case for my DSLR so its yes I use it in the rain very often.
And for my action cameras that I take underwater.
Yes.Like my float planes which sometimes take on water.Unplanned of course.Ok! ?
I don't have a water proof case for my Anafi (there is no) and for my DSLR.
So I stay away from rain with both cams.
The reason for my post #33 was my astonishment about discussing water resistance limits of a drone, that is not water proof.
Quite senseless ...
Hah! Me too! Great having that protection.I have a water proof case for my DSLR so its yes I use it in the rain very often.
Best protection of such a drone is not to use it under not recommended conditions.Yes.Like my float planes which sometimes take on water.Unplanned of course.
I don't fly my Anafi in the rain if I can help it.I DO fly it in light fog,keeping it VLOS.But weather changes and I protect what I own.I also fly in the winter and notice condensation as it warms up when I am done.It IS water resistant when I am done treating it.Not waterproof.
Senseless? No.Protecting an investment.Yes.
Nice dudeI was out this morning in light rain, some fog cover and all around misty type of day. The Anafi was wet tad wet but handle it no problem. As long as you do not expect it to fly in a down poor then its all good.
Always good to have a waterproof case.I have a water proof case for my DSLR so its yes I use it in the rain very often.
