SD Card in NTFS Format?
Drone Capt
SoCal
Will the Anafi support an SD Card formatted to NTFS?
It is annoying that we have a very high resolution camera but the SD Card formatted to FAT 32 can only hold a 4GB file, on longer flights using higher resolution video (2.7k or 4k) the video will get split into multiple files.
If it doesn't currently support NTFS, is it on the roadmap for future implementation???
This seems to be a short sighted overlook by Parrot.
No Anafi does not support an NTFS formatting on the SD card. It does not even support an EXFAT which is the official formatting for SD cards > 32 GB.
The video clips Anafi makes are all just under 4 GB in length. When you put them together in a video editor, you can't see or hear where the clips are assembled. Small video files are also much easier to work with in a video editor. Personally, I do not like having files over 4 GB lying on my NAS or as a backup on a DVD/Blu Ray disk.
If Anafi at some time vill supports a NTFS formatting ? Write to Parrot and ask the question. This forum is not run by Parrot.
clansman320
