I have modded the latest FF6 6.6.6 if it is of any use to others.
FF6_6.6.6_FCC_MENU.apk
Sorry, if I come from an old fw version, what is the exact procedure for have latest fw and FCC? I knew with latest fw as the bird gps see its located in europe it will force CE and there's no way to get out. Now I sold mine and I'm looking for an old fw version to purchase but I want to be sure
Hi all, starting situation
Position Switzerland
FF6 6.6.2 mod selectable
Anafi FW 1.6.3
Controller 1.6.2
WiFi Settings -> FCC OK CH44
Rooted S7 Phone No SIM Card
And now Long text ....
  • Set Phone in Fly Mode
  • WiFi ON
  • Alluminium over Anafi (for sure no GPS reception ;)o_O)
  • Fake GPS set in USA Kansas
  • Test GPS Position with FF6 download MAP -> USA OK
  • Update FF6 6.6.2.203 mod selectable -> FF6_6.6.6_FCC_MENU
  • Start FF6 and show me to update Controller FW
  • Controller Update 1.6.2 -> 1.6.3
  • Test WiFi Settings -> FCC OK CH44
  • Anafi Update 1.6.3 -> 1.6.5 (finger crossed:oops:)
  • Test WiFi Settings -> FCC OK CH44 :D
  • Battery FW Update -> OK
  • Power OFF Anafi / Controller / FF6 -> Power ON
  • Fake GPS OFF
  • Removed Anafi Alluminium cover
  • Test GPS Position with FF6 download MAP -> Switzerland
  • Fly Mode OFF All normal condition
  • Power OFF all again and Power ON
  • Outdoor GPS Position OK 9 Satellites and GPS position OK Switzerland
  • Test WiFi Settings -> FCC OK CH44 :p
Later will try connect with non rooted phone and FF6 6.6.6_FCC_MENU
Happy until now :ROFLMAO:
More luck than myself, since the last update I have been locked into CE mode. No matter what I have tried it will not activate FCC mode.
Just done the new update and battery update, and still the same.... CE channels only 1 - 11 and 149, 153, 157, 161, 165
I have just resigned myself to the fact that I am not going to be able to get FCC.
I was also given the opportunity to install AR.PRO 4 (Beta), which has many other tweak options. That seems to think I am in FRANCE, which is what I believe the 1.64 firmware locked me to :( Maybe time to get rid and move back to my MP
Reactions: Martre
Anafi FW 1.6.3
Controller 1.6.2
  • WiFi ON
  • Fake GPS OFF
Test with NON ROOT Phone (Huawei P30pro) normal GPS (no fake GPS)
  • Outdoor GPS Position OK (17 Satellites much more than before with 1.6.3 :unsure:) and GPS position OK Switzerland
  • Maximum altitude in FF6 6.6.6 150m (did not look before how many meters) geo fence was activated
Reactions: Gipsz Jakab
FF6 6.6.6 FCC and MENU mod.
Another thread mentioned that Parrot fixed an OBB download request bug and added a new version to the play store.
(This version enhances the battery level management and fixes the data synchronisation issue caused by previous version. )
Would you like to make the new version for FCC?
Reactions: Zigzag84
Is channel 44 better than 165 for range
Good question ... it depends if Parrot look where you are for WiFi power settings .... maybe ... :unsure:
Wikipedia WLAN
and
WiFi Power !
According this page ....
BandFreq. RangeBandwidthMax PowerMax EIRP
U-NII Low / U-NII-1 / U-NII Indoor5.150–5.250 GHz100 MHz 50 mW200 mW
U-NII Mid / U-NII-2A5.250–5.350 GHz100 MHz250 mW  1 W
U-NII-2B5.350–5.470 GHz120 MHz
U-NII Worldwide / U-NII-2C / U-NII-2-Extended / U-NII-2e5.470–5.725 GHz255 MHz250 mW  1 W
U-NII Upper / U-NII-35.725-5.850 GHz 125 MHz  1 W200 mW
DSRC/ITS / U-NII-45.850–5.925 GHz 75 MHz
U-NII-55.925–6.425 GHz 500 MHz
U-NII-66.425–6.525 GHz 100 MHz
U-NII-76.525–6.875 GHz 350 MHz
U-NII-86.875–7.125 GHz 250 MHz
FCC :
CH 44 -> is U-NII-1 -> Power 50mW (but EIRP 200mW)
CH 165 -> is U-NII-3 -> Power 1000mW (1W) !!! (but EIRP 200mW)
Normaly more power = more distance !
But IF PARROT looks where I am (Switzerland) then CH 165 is only 25mW :eek:
I have a Spektrum Analyzer that cover only to 3GHz .... can't measure it :(
Maybe I'm wrong ...
The question is how they chose FCC or not in FF6 :unsure: and how we can measure it !
Good question ... it depends if Parrot look where you are .... maybe ... :unsure:
Wikipedia WLAN
and
WiFi Power !
FCC :
CH 165 -> is U-NII-3 -> Power 1000mW (1W) !!! More Power = more distance !
Maybe I'm wrong ...
I'm in FCC mode tommor I will try both channels and see, on channel 165 I get about 1.5km in a town area in Ireland
Reactions: Gabriele_Da_Tos
Try to delete the obb file i think fix this. I downloaded ff6 6.6.6 modded fcc then download obb file and not require to be connected with wifi or mobile data to open app again. Now i m on 1.62 controller and 1.6.3 anafi i wait some days or week and do upgrade with fakegps active and channel 44 selected manually.
You see all fcc only channels 36 to 48?
You see all fcc only channels selectable in the wifi list 36 to 48? with last firmware 1.63 controller and 1.65 anafi?
I see Channels 1 to 11 / 36 to 48 / 149 to 165 with all updated and FF6 6.6.6 mod
Inviato dal mio VOG-L29 utilizzando Tapatalk
Reactions: Skassa
Does this mod have the data synchronization bug?
PeeTeess
