Hello Helder, I have version v6.7.3, is there a newer one? I hear about 6.7.4 with integration to Airdata and Direct Remote Identification, but on Android does not appear the update proposal.
Hello JCamilo -
Updated FF6 modded versions can be found in post #1 in thread below, towards bottom of page contains a link to folder on google drive
FF6_6_7_6_FCC_SE_BATTERY.apk - FCC with SE and Battery features is the latest version, but also contains older versions too
You are correct that Airdata integration is included in FF6 v6.7.4 and later versions and in fact it does work with android
Best of Luck!
Airdata doesn't work on Android at least ...even in FF6 V6.7.4
Hi sibujacob,
I can confirm that airdata does work with android starting with FF6 v6.7.4
What issues are you running into?
Reactions: sibujacob
Hello JCamilo -
Best of Luck!
Hi,
How is the latest Anafi firmware v.1.8.2 ...........Are there any issues related to battery holding its recharge state
Hi,
Hi sibujacob,
I have flown quite a bit with FW v1.8.2 and have not noticed any issues, seems stable
Also have not noticed any differences how batteries behave from previous FW upgrades
I am probably over cautious but I monitor batteries closely and make sure to provide proper care
Since I have multiple batteries I tend to only fly down to about 50%
Nice to have modded app and now airdata to help monitor voltages and cells
Best Wishes
Hello JCamilo -
Best of Luck!
Thanks and Merry Christmas
Reactions: BRC
Hi, next time, would it be possible to add an option to change the speed measurement from m/s to km/h?
Thanks.
Not heard from either of the two guys who mod the files for us for a while now.
@ds2atc Started it all off, followed by @AnafiPilot1 who actually modified further adding special features that were previously unavailable, and also adding the battery indicator to give us a better view of the battery status in flight.
Would be great to see either of them add the latest released version of FF6 to the currently available modified versions.
Good morning all. I have installed "FF6_6.7.0_212_FCC_Selectable.apk". all this connect but i don't have an image. Skycontroller 3 : 1.8.1 / Anafi : 1.8.2. an idea ? Thanks
I hsve the exact same problem when i install app from play store i get live video back
I don’t think the modified version of FF6 you are downloading is compatible with the latest FW versions for controller or drone
Try a different modified program created by AnafiPilot1. You can select standard or FCC version. Link below with downloads and instructions in post #1
Tried that too buddy still nothing iv noticed the screen to allow permission doesnt pop up
- If you have problem while initial synchronization,
1. Install FreeFlight 6 on official Play Store.
2. Navigate to /Android/obb/com.parrot.freeflight6/
3. rename the folder such as com.parrot.freeflight5
4. Uninstall the official app, and install FF6_FCC
5. rename the folder to original
I have Sync Problem-Internet Connection error on start-up...
Cannot do that since there is no FF6 in Google Play anymore...
What shall I do?
clerkza
