Screenshot
Free flight 6 is still there in Google play
Ok, solution:
- downgrade tablet to Android 10 (or buy a cheap one)
- install beta FF from Google Play
- save obb folder
- install modded FF6 👍
I am not clear on your question but if you are looking for a modded app for latest version of FF6 for Android app I have put link below look at post #1. Make sure you search through other users posts in regards on how to install and saving existing OBB file by renaming it and then adding back in with original name as necessary. I have never needed to do this but others have run into sync issues if not done properly. Btw make sure to select correct file off his sever as there a few different version to select from.
Good luck
hello and thank you, I followed this method but the application closes every time. I have tried the installation method several times but the application always closes.
Hi Stevanie
Sorry to hear this that you are having issues, I am curious on the following questions:
What Phone & Android version are you using?
What is your drones FW version?
What is the exact file name of the modded FF6 app are you downloading and trying to install?
Are you currently able to download and install latest OEM FF6 version app from play store without issue?
Do you have in app purchases for flight plan & follow me and are you using them?
Have you tried to download to a different phone or device to see if it works - if so what model and android version?
Install freeflight6 from Google play, then connect smartphone to computer via cable, allow all permissions to transfer files both on phone and computer, copy directory android/obb/com.parrot.freeflight6 from your phone to computer. Uninstall freeflight6, then copy directory com.parrot.freeflight6 back to phone to android/obb and install freeflight6 fcc. Google pixel 7pro with Android 14
Reactions: Stevanie
thank you very much, it worked perfectly. small question on the network level, now that I am in FCC I should rather leave manual or automatic for the choice? if manual which channel should I put myself on?
I think I messed up.
I uninstalled my OEM app of freeflight 6 from my tablet and as I go back into the app store, I no longer see the APK. I have free flight 6 on my phone though. Can I use my phone obb to transfer to the tablet with this modd?
All set. Got it running and going to test this thing out tomorrow.
Reactions: JawaHell
Spencer Burrows
