Tried to reset controller in the options? Not calibration.Mapping seems to be spot on. Wherever I place myself with FakeGPS, mapping shows it correctly. Even FF6 shows me in the map where FakeGPS is set. When I switch off FakeGPS, location is correct for my home site.
I have a feeling my Saturday is going to be filled with trying every conceivable option :-( Just zapped my XT2 which is rooted, and going to put he modded APK's on that...... But to be honest, I dont hold out much hope.... but one has to try!!
You update the anafi firmware with rc playstore app or with modded app then install playstore app?Yep Several times. Also tried again this morning, starting everything from scratch, and regardless whatever I do, only ever get channels
1 - 11 on 2.4 and 149 153 157 161 165.
As I've already commented, even with FakeGPS all the maps incl FF6 show me in USA or wherever I set it, so now convinced somehow its locked into the drone, with that being the only element that got upgraded.
This video is for DJI but I would think its pretty much the same process as with the Anafi. I know you tried fakeGPS already but does this video give you any ideas to try?
I have the 6.6.2 mod FCC and only see a drone update notification from 1.6.3 to 1.6.4.
(I DON'T SEE UPDATE FOR SC3 _ 1.6.2 Now)
Are you sure if I update the firmware to 1.6.4 without changing the 6.6.2 mod FCC, will I continue to get FCC?
I'm using 6.6.2 mod FCC
Anafi updated to 1.6.4
Have just checked, and yes I still have the previously manually set channel 165 which I'm pretty sure is a FCC only channel.
Yes it was part of the Jan 31st update. Most of this update has to do with the thermo.new update on the Skycontroller - version 1.6.3. No information on de the parrot website however, so not sure what it does.
