Hi all
I was using a Samsung EVO 64GB card on the Anafi with success, although it's only rated as a V10.
I use either a Android Phone with Freeflight 6.4.1 or a iPhone with 6.4.0. My Android phone doesn't fit very well on the Skycontroller so I got a iPhone SE.
I had removed the card and formatted it on a windows machine as FAT32 and when back at the Anafi I got a Red Card error and with no options to proceed from there, while I was using Freeflight on the iPhone.
I got a Linux machine and formatted the card on various FAT flavours with no success getting the card recognised by the Anafi. Then back at the Windows 10 machine also tried the FAT variants still without success getting the card to be recognised by the Anafi.
I then started the Android version of FreeFlight 6.4.1 and surprise, surprise, the same Red Card error, but this time there were options to format the card....which I did and no more problems.....
Just to be sure, I got another EVO64 card that was never used on the Anafi (used previously on a GoPro camera) and the card was not recognised.
This time I used a Mac to format the card on both FAT flavours and no luck getting the card to be recognised by the Anafi, and also no option to format the card on IOS, but the format option was available on Android.
Side note. None of the 64GB cards formatted by the Anafi/Android Freeflight combo are recognised by either Macs or Windows only on Linux. The supplied 16GB card even when formatted on the Anafi is correctly recognised on all computers....
Attached is how Linux "sees" both a 64GB and the 16GB cards that work on the Anafi.
So, I believe the "solution" for now is to format the cards using the Android Freeflight 6.4.1 app.
edit: didn't try the app to format cards from the sd card association
edit2: tried with the latest version of the sd card association tool and it is the same as formatting on pc/Mac, so it's a no go.
Watch our video on how to use the SD Memory Card Formatter SD Memory Card Formatter 5.0.4 for Windows, 5.0.3 for Mac (SD/SDHC/SDXC/SDUC) The SD Memory Card Formatter formats SD Memory Card, SDHC Memory Card, SDXC Memory Card and SDUC Memory Card (respectively SD/SDHC/SDXC/SDUC Cards) complying...
www.sdcard.org
