Sure & there are always translators for those that don't.Sure, do you read Slovene?
Sure & there are always translators for those that don't.![]()
I have been working with someone who makes programs to read telemetry files and displays the output with errors if any are found. His specialty is with Yuneec drones but I thought I would pick his brain and see if he could make a similar program for our Anafi's.
Here is a link to what he has so far:
http://h-elsner.mooo.com/downloads/ShowAnafiLog.zip
By "controller device" you mean Skycontroller 3? and if so which is the right usb port? USB A? or USB C?
Unfortunately I don't have my last flight logged here! - iPad air2 wifi only with FF 6.5.2
I have not worked out exactly how it works but the flight logs only show the 1 flight before the last flight - so if you launch Anafi and land again, then look at flight logs - your last flight + 1 will be shown.
Hope that makes sense!
Is there any way to read the log file of the sd card?
Is there any possiblity Skycontroller 3 to have logs inside?The log files are not readable from the SDcard. If you have no flight data on FF6 then they will not be on your parrot account either. Seems your out of luck.
Thank you *very* much for the links. I will try to repair and will let you know.Here are two programs that might help get your video back. Good luck.
