Freeflight 6 mod app
22days ago,
14days ago,
And yesterday,
I can't believe how he said
"THERE IS NO IMPACT ON THIS."
and
"THIS IS A DEVELOPER FORUM ONLY"
As Jerome said in the dev forum, there's no workaround on the SDK side(app).
The only fix is the firmware update.
Thanks a lot for keeping us up-to-date ?
South-Korea : only country so far to fight efficiently against coronavirus ?
22days ago,
14days ago,
And yesterday,
and
Hi ds2atc, I see you are in contact with Parrot. They are giving us hope to release new firmware to Anafi to flight in FCC mode in Europe ?
No, they will never release an official firmware that enables FCC in Europe. Their CE, KC, and many other certifications will be canceled if they do that.
However, the country selection is a part of the SDK, so user's will be able to change the mode without the official one if the firmware problem is solved.
Practically what does all this mean for us ordinary users?
Can we hope to get back to balance like with FF 662 and FW 1.6.3?
I wish you and your country the strength to resist the attack of the coronavirus .✌
Yes, the manual country selection will be available again if they fix it.
I
I'm sorry for my ignorance but what is it SDK ?
When it showed here in Canada it first said April 1st then I noticed later on it was changed to April 2nd.
Now it is here with us (Hungary) April 2 is the date. Either they realized it was a notable date, or it was another release (bug fix) in secret.
South Korea is strong on track!
But we should not forget about Taiwan!
Just because China makes most airlines fly to "Taiwan, China", it is still undoubtful NOT MAINLAND China!
And doing good, with only 5 dead and 50 infected, so far
(John Hopkins, ArcGIS Dashboards )
making a patched version for IOS is a totally different ballgame to the version for Android. Much the same on the DJI scene, everything concentrated on Android version as it allowed access to file system much easier than IOS ever will be.
I've one question :
in the Opening Thread there are this possibilities :
Zitat:
- If your Anafi's version is 1.6.3 or lower, you have 2 choices:
1. stay at 1.6.3 since there are some issues with v1.6.4~1.6.7.
2. update your drone with the modded app only
- Update 1.6.4 with 6.6.2.203_FCC
In this moment my Anafi is still on 1.6.0 and the controller 1.6.1.
Not 1.6.3!
The mod App give me the possibility to Upgrade to 1.6.4. (Update for Controller and Anafi is available).
If I want to stay with the current Firmware on the Anafi /Controller (till the current issue is solved) , can I use the mod Version 6.6.2.203 or does I need a lower Version?
If yes, which one.
The reason is, that - I'll believe--something is changed between the app and Controller /Anafi and I don't want risk a crash or fly-away.
Should I use this version (6.6.0.1)
Or can I stay still on 6.6.2.203?
Reactions: Wowwowwo
Jo Van de Vyver
