@ds2atc Thanks very much, **** super quick on these now, you must have the process off to a "T". Thanks again for doing these, sure everyone very much appreciates your time and effort ?
yeah... it became very simple...
only 5 minutes for creating FCC mod, and only 2 minutes for adding ALT mod. :D
2316
We need to make sure you dont go anywhere :-) as there is nobody else doing this for us, so we must keep appreciating your time and effort to give us this modified application. You are keeping us all happy..... Thanks
FF6 6.5.2 FCC MODE
FF6 6.5.2 FCC & ALT MODE
I haven't tested this for actual flight because my drone and skycontroller are not charged, but it should work since there's no change on wifi/geofence files.(They shoudn't be changed because they are from the groundSDK.)
App opens, load maps, 500m on flight plan works flawlessly.
OBB for 6.5.2
1. Download the file
2. Install apk
Ds2stc : Thank you very much for your effort to provide this app.! It really enhance the anafi flying experience. It do extend the flying range! Good job!
[QUOTE = "ds2atc, post: 20261, membro: 1230"]
FF6 6.5.2 MODALITÀ FCC
[URL unfurl = "true"] ff6_6.5.2_FCCMODE.apk [/ URL]
FF6 6.5.2 FCC e ALT MODE
(usa touch & fly waypoint o piano di volo per sorvolare 150 m)
[URL unfurl = "true"] ff6_6.5.2_FCCALT.apk [/ URL]
Non ho provato questo per il volo reale perché il mio drone e il mio skycontroller non sono caricati, ma dovrebbe funzionare poiché non vi è alcun cambiamento sui file wifi / geofence. (Non devono essere modificati perché provengono dal terreno SDK).
L'app si apre, carica le mappe, 500 m sul piano di volo funziona in modo impeccabile.
OBB per 6.5.2
[URL unfurl = "true"] main.60502204.com.parrot.freeflight6.obb [/ URL]
Scarica questo file se il telefono non riesce a sincronizzarsi.
1. Scarica il file
2. Installa apk
3. Crea una directory (cartella) /Android/obb/com.parrot.freefligt6/
4. Copia il file nella directory che hai creato.
[/ CITAZIONE]
Good job! One question: just download the mod app or do i have to do some other action? Thank you
File attach test
OBB per 6.5.2
1. Scarica il file
2. Installa apk
[/ CITAZIONE]
No, if you see channel 36~48 on you app that means your drone & app are in FCC.
Reactions: Moonfly
FF6 6.5.2 FCC MODE
OBB for 6.5.2
2. Install apk
can you better explain how to carry out the precise procedure for the 6.5.2 FCC & ALT MODE version?
1. Install FCC&ALT version
2. Fly over 100m for your safety
3. Choose Touch & Fly. You will see "waypoint" next to Touch&Fly button.
4. Touch the map so that it creates a waypoint.
5. Slide the bar on the right side of the screen to set your drone's altitude.
6. You can go higher only using the slide. You can go lower using the controller or slide.
Hi, have you idea, can we change drone wifi SSID name, and still use with FF6? or with mod FF6 fixed for such change of SSID?
Known common used SSIDs are the only way where some kind inventions of "searching guns" can track drones on the air. I suppose. :-)
I've uninstalled and installed the app v6.5.2 and rebooted the phone a few times, but I still don't have 36-48 channels. LG V30. What could be the problem?
Thank You very much for your fantastic work!
I hacked the altitude by backdooring the flightplan. That was really less comfortable.
But now including FCC-Mode, this is awesome to me!
Thank you so much!
Best regards to you and your family!
Reactions: Zigzag84
Information for those who want to manually edit the flight altitude in the flight plan file.
On Android devices, the file is saved in this folder:
/storage/emulated/0/FreeFlight 6/flightPlan/[name of plan]/savedPlan.json
where [name of plan] is the folder name that matches the name of your plan.
Or they could just follow the tutorial located here:
Excellent work ds2atc!! Much appreciated!
Is it possible for you to do the same for FF 6.4.3?? I run this on my Moverios and DJI CrystalSky monitor...can't update it, since old Android version.
kathrynemma20
